OkiePC
We never figured out what was killing the PV300 Micro. The environment is hot and steamy and there are acidic gases in the room at times. The year we gave up on them we lost 5 PV300's in four months, and our usage history showed that we had used 6 of them in the previous year on that same application. They had already tried putting a membrane over the face of the PV300 but all that really seemed to do was make it hard to operate. I tossed that membrane after a month with the G304K installed to see if it would die.
At one point we replaced the 24vdc power supply, and I even put my meter on peak hold and left it in the panel for hours and saw the voltage was solid. I even power cycled the 3 phase supply to see if I was getting a spike, but all appeared normal. This was when I put in our last PV300, and had the G304K requisitioned. I was still programming the G304K when that last PV300 micro croaked about 3 weeks later, so I hastily wrapped up my editing and stuck it in there, the only other change was to install my home made cable and cut the opening slightly wider in the fiberglass panel.
My parts room guy ordered two spares of the G304K expecting them to fail after a few months, and those two spares are still sitting on the shelf, programmed and ready to go if the first ever does give up the ghost.
EDIT: I just reread the 1st post about a wrap machine. That application never happened, since that machine rusted in half and now sits in the bone yard, so my last couple of posts are in reference to a different application on a pump panel for a waste water treatment system.
