Red Lion Graphite on Ethernet/IP Network with CLX PLC
einnh
Mar 2014
New England
275
Quick question.
If I install a Red Lion Graphite HMI w/ one of the digital input/output modules attached to an Ethernet/IP network with CLX PLC is it possible to map the IO on the Red Lion unit so it's readable from the PLC?
Example, attach an operator button to the Graphite unit IO and have that status available to the PLC.
Thanks,
Eric
I have never used the onboard I/O but, you should be able to map the I/O to a RL Flag Tag. Then map that Flag tag to a PLC BOOL Tag. Set the RL Tag Access to Read and Write or Write Only.
Then when the RL Flag Tag goes true the PLC will read it and set the corresponding tag true.
I've used a number of them already. Create a tag in your PLC then import to Crimson. Add a gateway block with that tag, then drag whichever I/O to that block. No need to create a tag for the RLC I/O as the module shows up as an option to select from. Pretty simple, and works great.
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
Does anyone know a quick answer to the difference of a red lion G10C1000 vs G10C0000. In crimson it shows an aux ethernet port. on the web site i...
1,457
Hello all. I am struggling with an analog output from a Red Lion Graphite HMI with a GMOUT4 module. I can watch what the data should be (currently...
1,373
I have a graphite HMI and 3 PAX panel meters. I have tried using RLC and Modbus Master drivers, 2 different cables, with and without Comm...
1,879
Hi Everyone, Got a new project where I am going to read the level of a tank via Modbus and I need to use the tank strapping chart to convert it to...
2,534
