Red Lion IOs with AB CPU
Yes... probably many ways. Which IO, and what are you trying to change?
I think an Ethernet/IP slave driver on the Redlion with the entries mapped to the Internal variables created for the IO modules should work. (I have not tried this.)
Csmstrv
Robert,
CSMSTRV series IOs, specifically PID controller modules, Temperature controller modules, Digital IO modules and analog input modules.
These IOs are currently connected to a RL G315. The entire program logic is in this G315.
The need is to move the program logic from the G315 to CompactLogix (L32E) and make the HMI as only HMI instead of controller & HMI.
The RL documents (1, 2 ) INDICATE it can be done, but I want to make sure before venturing into it.
Anand
How do you connect the IO to a G315? I have never seen it be able to attach to the panels, only a Master Controller. What comms protocol are you using now to connect the G315 to the Master Controller?
Modbus
Robert,
My mistake. I wrote it incorrectly.
There is a master controller and that is attached to the HMI.
Modbus TCP/IP - Master (HMI) - Slave (Controller)
But still, entire logic is in HMI as Chrimson doesn't show option for programming the controller in this series.
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
70
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
277
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
290
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
126
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
245
