Red Lion to Emerson EN
BlueAltezza
Nov 2012
Cleveland, OH
243
I was given a fun task of replacing an old Maple/Emerson OIT panel with a Red Lion G307K2. The screen connects to an Emerson EN drive with FM-4 Module.
The Maple still works, but the customer received two new units that use Emerson EP drives with Red Lion screens (over Modbus TCP/IP) and wants to upgrade some old units.
From what I dug up, the Emerson EN is a Modbus RTU slave over RS-232 (19.2k, 8 data, 2 stop, no parity). I can connect to the drive with my PC and the old Maple, so the drive is good to go.
I just can't talk to the drive with the Red Lion.
I took my Red Lion file that's designed for Modbus TCP/IP and changed it to a Modbus RTU Master over the Comms port - RS232 mode.
I followed the wiring from the Kadet manual and can't get any communications. I read many other posts regarding the Kadet documentation having RX and TX flipped, so I tried flipping those as well.
I've also tried using Com 2 (setting the programming port to Modbus Master), and Com 3 (setting the aux port to Modbus Master).
My last effort was trying a G304K2 and following the wiring for that. Still nothing.
I also created new files with a few basic tags for each Red Lion with no success.
Any suggestions? Red Lion tech support wasn't much help, but I give them credit for not having me on hold for an hour like some other manufacturers :)
I have a feeling it's something in the driver or settings. All hardware checks out fine individually.
Thanks in advance!
Can you post your Crimson Database (zip it first)? That way we can see how you have everything set up.
Hello all, I know this is a very niche question, and a long shot. I'm in dire straits and I'm looking for anyone with some experience using Red...
2,911
i thought i would start a new post to help advoid some confusion on some previous questions i have asked while working on this. i attached two...
6,626
Could someone lead me in the right direction? Using Crimson 2 and a 306 hmi unit how would you set up the allen bradley micrologix 1400 plc to be...
17
8,622
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
59
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
273
