irondesk40
Could someone lead me in the right direction? Using Crimson 2 and a 306 hmi unit how would you set up the allen bradley micrologix 1400 plc to be able to reference a servo drive that I can currently turn on manually from the HMI unit with a manual Pushbutton.
Basically when I push the push button on the plc it turns on a bit in the servo drive which is referenced as Register 18_Data Word 1_Bit2. The Modbus address is 41812. Then in the servo drive I have a program that will perform a index move when 41812 goes true.
How can I take the Micrologix 1400 plc and have it linked to the servo drive that is connected to the Red Lion HMI and in the PLC have it reference for example modbus address 41815 in the servo drive?
If i understanc correctly I need to set up some type of data block assigned to the modbus address in the drive.
Any advice would be helpful. Has been a challenge at the moment, but slowly learning from reading post on this site.
