Is there a way to link a bit such as B3:09 so that if it was to come on it would also make the Bit_Index_Run that is referenced as a tag in the HMI file to turn on as long as the B3 bit was true?
Basically the Bit_Inex_Run be turned on from the HMI or the PLC. Not have the PLC linked directly to the drive but directly to the Bit_Index_Run tag in the HMI, that way the drive would still only be controlled from one source. Thanks
