redlion controls
neekheeldesai
Dec 2003
qatar
dear friends,
hi ,I have redlion controls' paradigm SL-15 and SL - 40 display.
SL 15 is connected on quantum plc using proworx and SL 40 is new spare.
The connected one has stopped communicating to PLC ,not updating any Tag data,so I want to connect it with PC loaded with EDICT-97 S/W,and I want to download program to SL15 or SL40,So can anybody tell me the pin diagram for programming port RJ11(on SL15) to rs232(of PC) .Or can I connect PC on SL 15's RS232 PLC communication port.
Thanx.
Modicon port
I don't know anything about the Red Lion but, the pin out for the Quantum is:
Pin 1 - Shield
Pin 2 - RX
Pin 3 - TX
Pin 4 - DTR
Pin 5 - Ground
Pin 6 - DSR
Pin 7 - RTS
Pin 8 - CTS
Pin 9 - no connection
Note: Pin 7 should be jumpered to Pin 8 at the PLC.
dear Jim
thanks for the reply,I already have PC pinouts.what I need is cable pinout for Redlion SL 15 to pc connection.which is RJ11 - D9 female.
thanx
regards
nikhil :p
red lion controls
Dera Jim
Pl read PLC instead of PC in my previous reply.I have modicon plc pinouts,I need pinouts for a programming cable to program Red lion SL 15 module.and for that RJ11 to D9 rs 232 cable required.RJ11 will be connected to SL15 and D9 will go to laptop com 1 port.
regards
nikhil
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
227
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
661
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
829
