Redlion Dual ethernet & OPC
mjoubert
Jun 2007
Pietermaritzburg, South Africa
192
Why does OPC workx only accept the main ethernet IP (reads this from the cd2 file) and not the auxillary ethernet IP.
The main ethernet IP is configured for Fins Protocol. The auxillary ethernet IP is the one that does not support drivers, and is the one I would like to connect to my factory network.
o_O
Hello,
Neither of the ports are link to the drivers. The drivers just happen to be listed below the main ethernet in the comms tree. The system looks at the destination IP of each packet and determines which port it should be sent out of.
Also regarding OPCWorx, you can manually change the IP address after it has been read from the .cd2 file.
Jeremy
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
226
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
661
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
829
