Redlion G3 - Adding string data to data Log
shiftedbits
May 2007
CALIFORNIA
62
Is it possible to add a "STRING TAG" in to a data log?
I want to be able to add words like "Monday", "Tuesday" etc. in to my data log. It does not matter if the word repeats for the entire duration of the log. Don't have a screen to try it on at the moment and wondering if anyone has been successfull in doing this. My simulation craps out every time it starts. I've only gotten it to work once. Now it just errors out every time the Sim tries to run. (Using crimson 3.0 Latest version).
Yes it is possible to put strings in Data Logs. All you do is put the tag in your contents list. You basically handle it the same way you handle a integer or any other tag you want to log.
Thanks ClayB,
Is it safe to assume that Redlion does not do a Byte swap automatically (as some HMI's do) when it reads a string Tag from a PLC?
Only if you want it to. You do have a bit and word swap option when you set up Comms but default is none.
I don't know about the security logs (haven't used them much, and usually make my own) But for an alarm, you can make a string for the eventname. It will need to be in string format, and use the = sign to tell the program you are not entering a direct string. You will also need to build a program to accept an integer (day of the week), and return a string (with your text for that day). If you only need it once a day you can trigger the alarm based off time.
=Program0(getday(getnow()) + "Log Start"
In the manual (build 454) pg 79, it shows this feature using a array
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
146
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
178
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
236
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
667
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
834
