RedLion G3 and AB Pico
The cat# is a 1760. It is the lowest function PLC AB has, I don't believe AB even makes it. They buy it from someone and relable it. The cale has a 9 pin D-sub for connecting to a computer and I believe it is RS232 comm's. Currently it have it connected to the G3 using a CBL0MR01 with no luck so far.
David
From what little (helpful) information I have found since we talked on the phone last week, it does not appear that the serial port on that unit is good for anything other than programming. The 'communication' that is mentioned on their web site looks like it is a proprietary link used to connect more than 1 PICO together.
Regards,
Dan
No, the AB Pico's were already there. I am looking for a low cost unit.
My main goal is to use the G3, however, I need 1 0-10V in and one digital
out.
I have just finished an application using a G303 connected to an AB Micrologix 1100. There are three different models of the Micrologix 1100. They come with two 0-10V inputs and have digital outputs (if you buy the correct model).
With the majority of smart relays, unless they offer some sort of interface module, they are not designed to interface with a display.
Some units do offer a communications module, such as ModBus, but that only adds to the cost.
Unless you have the software for a Micrologix 1100, that cost will likely be out of your price range.
Based on the minimal number of I/O plus the analog input you will require, we offer a product that can handle that and it includes the programming software. In addition, it can be ordered with a ModBus RTU driver for communications to the Red Lion G303.
More information can be viewed at www.entertron.com/smart-pak.htm
Disclaimer - I am a employed by Entertron Industries.
Hope this helps.
God Bless,
The majority of smart relays, unless they offer some sort of interface module, are not designed to interface with a display.
Hope this helps.
God Bless,
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
825
