Redlion G3 HMI - Calendar & DST
Marc_U
Sep 2006
Cumbria
193
I have a G3-10 HMI, which has to do some date/time set actions.
To when does is the G3's calendar run to?
Or put it another way, what is the last date/year that the HMI can run to?
Also, can the HMI automatically adjust its Real-Time clock in line with British Daylight Saving (DST)?
And if so, how do I enable it?
Marc,
I can't tell the exact last day available in the internal calendar but I can say that we will have all moved on to other things before we reach that number :). The calender uses a 32 bit register which will give us many many more years.
The unit can't auto adjust to DST because each location changes differently. You can toggle the UseDST() variable manually when you would like to make the change.
Marc,
Thanks, your answer came just in time. I was within only a couple of hours of leaving site, when I got your answer. Just time to add a DST toggle-switch, to enable the customer to change between DST Summer/Winter time.
Thanks again.
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
828
Hi, I am using a Micrologix 1400 for a project, and we were supposed to use a 4.3in PanelView HMI. By means of delivery times, that won't be...
984
Hi Experts! I am trying to get a Redlion Crimson 3.0 HMI to talk to a Rockwell Emulator. I imagine I'll have to use OPC DA. Has anyone done this...
1,179
How to change Daylight saving time ON/OFF automatically in Crimson3.0&3.1/Redlion HMI How to change Daylight saving time ON/OFF automatically in...
2,190
