RedLion G3 Link Type
MATT116
Dec 2009
Dallas, TX
330
I'm currently using Crimson 3 build 252
G310 HMI
Communicating Ethernet to 3 SLC 5/05 1747-l551 Ser C Rev C
In crimson under network > protocol 1 > device > protocol options > link type "use shared socket" or "use dedicated socket"
My question is when would I use shared socket or dedicated socket and how does this affect communications?
The most common use for sharing a port is so that you could pass data from one port into another. This is done when you go thru the G3 via ethernet to connect to a PLC that is connected via a serial port.
You can also use a shared connection if you have more than 4 Ethernet devices connected at once to the redlion. It can only talk to 4 over ethernet at once, (dedicated). In shared mode, it establishes a connection then shuts it down when done, allowing you to program it to more than 4 Ethernet connections.
MATT116,
wutnots is correct with his explanation. Clay B's explanation refers to the port sharing selection.
Jeremy
Thanks again for clearing that up. I highly doubt I will ever need to use port sharing in my applications but at least now I know.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
145
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
178
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
236
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
667
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
833
