Redlion G3 Quickplot variable limit
JBooth
Oct 2013
Palmetto, Ga
70
I have started setting up a widget on a G310 that does the same job as a faceplate for a panelview for the ethernet switches I am using on my network. Running into some issues getting data limits on a quick plot to work as I want though. In the interest of less tags and primitives in the widget, using one numeric tag as an index, being ramped up or down by buttons, that changes the source for the numeric tag that is set up for quick plotting. So the data range can be drastically different depending on if source is say 'Bandwidth Utilization' vs 'RX Unicast FPS'. Would like to test the current set of plotted values for min/max to use as limits, for both the quick plot and a vertical scale, but not sure how to access that data in complex code. Does anyone here know of a way to get at that data in code?
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
825
