Redlion G3 with Honeywell UDC3200
mohmes
Jun 2011
Oak Ridge, TN
I have a furnace control system which uses a Redlion G308 (using Crimson 3) which communicates with 12 Honeywell UDC3200 temperature controllers over Ethernet Modbus-TCP. I am constantly losing communication with the UDCs and have had to implement some very unellegant code in order to ensure that the operation parameters are sent down to the UDCs.
If only one UDC is on the system it seems to work fine, but difficulties start increasing as the number of UDCs are increased.
Has anyone work with such a system and if so, how were you able to get the communications under control?
Thank you in advance!
Martin
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
182
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
240
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
670
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
836
