RedLion G306K (Kadet)
George Graziano
Jul 2004
NY
447
I am finally able to download to a G306K, but it doesn't act like it is communicating with the PLC. The PLC is Allen Bradley 5/03. Using DH485. So my adapter is a CBLADK04 and plugged into the DH485/PC port on the Kadet. On the 5/03 it is plugged into the top port. On Crimson 3, I have it set to RS-485 Mode- DH485 master. Under that I have created PLC1, on the right side, Enable device, device SLC, drop # 1. Not sure what is not right.
George
Thanks to Red Lion for the help. I had my PLC under the Communications section, it should of been under the Network section.
George
I'm having problems getting a MLX1100 to work with a Redlion G306K through Ethernet. All I want to do is put a pushbutton on the screen addressed...
1,375
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
