Redlion IsDeviceOnline()
moistcat
Jun 2020
Melbourne
54
Redlion DSPSX001
Crimson 3.0
Im polling 3 modbus devices via RS232 serial plugged into redlion, and I want to create SCADA alarm upon communications fault. SCADA Polls the redlion via modbus TCP
From the gateway, i have assigned a tags to the function IsDeviceOnline(2), where 2,3,4 etc is the device index.
I then read these tags are then mapped to modbus registers read from SCADA.
When i unplug the device '2', the tag FF1BEKA001 stays true but pulses to false every 1s approx (for less then 250ms).
Does anyone have a better way of achieving what i'm after?
Not much help, but you seem to have done everything right, following this RedLion tech note:
https://support.redlion.net/hc/en-us/articles/7781952535693-Crimson-3-x-Detect-Comms-status-
What does the tag do if not mapped to Modbus registers? I always start simple and then add complexity if the simple stuff works.
edit: Thinking about it, can't you set the poll rate for a Modbus device. If you poll it quicker than it can respond then you would get bad connections, followed by a good connection, cyclically.
I was wandering if GETDEVICESTATUS() might tell you more about what is going on with the device at least to help trouble shoot it. Just a thought?
Im currently building a file for a redlion Productvity unit "PTV". Pretty sweet device! I'm trying to setup a page to display comms failure and...
3,116
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
