RedLion ModController Communication
icemangreen
Aug 2007
Indiana
Is there a way to detect active communication between a plc and a redlion mod control? I need to disable my heat controls when the communication between the mod control and plc are interrupted. Normally I would use a heart-beat timer between two PLCs, but that doesn't appear to be a viable option here.
What Redlion Controller are you using? I think all of those controllers run Crimson, so you should be able to write a script to do the heartbeat. Write a number to the Redlion, have it read the value, increment it by one and write it to a different location where the PLC can read it back.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
143
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
176
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
233
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
665
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
832
