Redlion Productivity Station PTV Mouse
dpslusser
Jan 2016
PA
48
No question - just an FYI
I recently had a customer who was using a PTV with a local display using the DVI port. They wanted to move the monitor to a location that was about 25ft (of cable) away and keep the use of their mouse.
Well, we all know that the limitation of USB is limited depending on what standard of USB the device is. In the Redlion PTV's case...it is USB 1.0 compliant. So I went to town with purchasing roughly 8 different styles of extenders. But with USB 1.0 being so old, it took purchasing different extenders to find out that even the backwards compatible units would not work. After I thought I exhausted all options, minus moving the Redlion PTV to the customers desk, I happen to run across this http://www.monoprice.com/product?c_id=103&cp_id=10303&cs_id=1030313&p_id=6042&seq=1&format=2. And it was only by accident, while I was purchasing some supplies. If you notice, this device is USB 1.0 ONLY. Not a 2.0 backwards compatible device.
Since I was placing an order and for the cheap price, I bought it. And to my surprise is worked with a 30ft network cable.
So for anyone wanting to use the PTV with a mouse, farther away than 5ft, purchase the Monoprice extender Part#6042.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
128
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
228
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
662
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
829
