Redlion's new G3 Kadets
I just saw a demo of the new Redlion G3 Kadets. It has a very low price (AD low) and looks great. It is plastic but most cheap screens are now days. The only bad thing is RS232 only.
All I saw was a demo unit. Has anyone one got to do any work with one? I would like to see if the trends work the same as the other G3's
http://www.redlion.net/Products/HumanMachineInterface/ProductFamilies/G3Kadets.html
The 4' only has serial RS232,422,485, but the two larger unis also have ethernet. Per the link you provided. No I have not used one.
Id love to try these out but our systems require a little leeway with the power supplies as we use alot of solar/wind for charging. a buddy of mine tried the older style out and had problems if the voltage was above 26 or so volts. the panel would flicker and everything else. looks like the 4 inch may work but the other two wouldnt. its sad because these guys have alot of nice features that I could use.
The flicker issue has been resolved. We changed the voltage regulator design to correct the voltage dips that were causing the backlight to dim.
Regards,
Dan
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
182
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
239
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
669
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
836
