Redundant Profibus connections
prdutta68
Feb 2009
Jamshedpur
I have to connect two S7400H Hot Redundant systems. Can I use two DP/DP couplers i.e one for each channel?? Instead of using one DP/DP coupler with Y links on each side.
Hi, Greetings for all of you. Please find the attached system configuration of GE RX3i redundant system. We have to communicate 2 Siemens...
1,852
G
I am working on a project where there is an S7-417H PLC with ET200 I/O on redundant profibus. One of my I/O drops has 1 pair of existing fibers...
7,009
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
144
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
170
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
313
