Redundant Switchover Failure and Two Lower Nodes
justjack
Jan 2012
SC
I have a redundant ControlLogix system that fails during switchover. I have seen the answers to similar questions stating that redundancy requires two lower nodes in my network, and believe this is likely to be my problem. I have multiple nodes on the network, but all have higher addresses.
1) Is the solution as simple as reassigning addresses to the controllers or some other ControlNet device?
2) If so, what steps do I take to do this without interfering with anything else in the system?
Welcome to the Forum.
You're likely correct: the way that the ControlNet modules "swap nodes" requires them to be momentarily disconnected from the network, so they cannot fulfill the "moderator" role that the lowest-numbered device usually plays. This results in a ControlNet network restart, and thus dropped Connections, if there are not at least two other live nodes on the network at lower node numbers.
Details are in Chapter 2 of both the Standard and Enhanced ControlLogix Reundancy User Manuals, 1756-UM523 and 1756-UM535, both on the RA Literature Website.
In my most recent ControlLogix Redundancy system, we made the I/O racks nodes 1,2,3,4,5 and the controller chassis nodes 10 and 11.
You can't make these changes to an operating system; you will need to shut the whole thing down, re-configure the 1756-CNB(R)/CN2(R) modules (rotary switches), reconfigure the target addresses in RSLogix 5000, reload the program and reschedule the network.
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
284
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
171
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
302
