Refresher on Panelview... reusing file with a new PLC: Tag considerations
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I'm working with a Panelview for the first time in a long while, and I'm thinking through how I'm going to reuse a file from a machine the customer had me copy to create the new (used) machine. All the tags are the same, except the controller name (on a CompactLogix 1769-L33ER) is different. Will I need to update all the tags on each screen one at a time, or is there a way to batch change all the tags to the new controller?
The actual name of the controller isn't used anywhere in FT View. Instead, you create a shortcut (in FT Linx Communication Setup) for each PLC device. That shortcut gets assigned a name of your own choosing. Just make your new shortcut name match the one in the existing program you want to reuse.
That would be easier than trying to change the name of every reference in the application.
OG
It's been a long time since I've had to think of P&ID tag nomenclature myself (and not gone along with some scheme devised by someone else). I've...
243
It's been so long since I've been inside of Modicon. Hope you can refresh my memory. Is it required to declare specific 400,000 addresses as...
1,509
https://www.youtube.com/watch?v=JPn5Ou-N0b0 A good refresher video for the Electrician members on here... A better explanation than what I was...
1,278
I am setting up alarms and the triggers. I want to use the bits of a DINT for my triggers. So, under the Triggers tab I have selected my DINT...
1,479
