Regarding controlling 12V DC motor
Jan 2018
Hosur
Hi all,
I need to control a PMDC motor speed using a PLC. Currently I am using manual potentiometer to do the same. The motor operating voltage is 0 to 24V.
PLC analogue output available is 0 to 5V. With this 0 to 5V I need to control a potentiometer which will regulate the voltage from 0 to 24V. Please suggest me the suitable potentiometer or similar hardware that will do the same.
If I understand your system right, you have a PMDC motor controller which need a 0 to 24 volt input to use the full available speed control, isn't?
What I like to use for (PM)DC motor control are the Roboteq controllers, which are easy to adjust to your needs.
Yeah that's the requirement. But I don't have a motor controller. Currently I am controlling only On/OFF thru relays using PLC program. But I need to change the speed of the motor so I am thinking to put a manual potentiometer to adjust the input voltage. But my final requirement is to control it in PLC program using analogue module.
Is there a way to do that?
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
78
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,033
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,120
1,945
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,143
