Regarding DDV instruction in AB
flyers
Sep 2006
Amk
295
Hi guys,
I've come across one of the program which consists of DDV instruction. I tried to search the help & instruction manual, the explaination is just very brief.
I know it consists of Source, Destination and relative to Math register which is S:13 & S:14.
If I'm correct, the S:13 & S:14 is the combination of 2 16bits value to form a 32bit value (>32767).
The 32 bits value (S:13 & S:14) will be divided by the source?
Hope someone can guide me. Thank you.
Your post is correct. You do need to make sure that the DDV is used immediately after another math instruction that would correctly populate S:13 and S:14.
Keith
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
77
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,028
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,120
1,942
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,122
