Remote I/O and HMI for a test stand
pauly
May 2002
South Wales,U.k
244
I was looking at installing some remote I/O and possibly an HMI into small mobile desk. The desk will be used to control two motor controllers for start/stop speed and torque for a test stand. The existing unit has potentiometers and a simple analogue display for speed feedback. Instead of running multiple cables back to the main panel and leveraging more operator information, I thought about a communications link (profinet, Porfibus, ethernet/IP, nothing decided yet).
I believe the existing, lets call it an operator console, gets unplugged and plugged in to the three different test stand areas as required. I believe only one stand is in use at a time.
So my concern is the connection and disconnection of any communication.
Has any body used HMI's or remote I/O like this before? I would be interested in any feedback. I have toyed with the idea of wireless Ethernet as well as there is around 30 meters between the furthest unit and the main panel
Certainly no problem with an S7-1200/1500 system with Profinet I/O and KTP TP being plugged/unplugged.
I've used the Maple System HMIs to simulate IO to the PLC. You have to do a little bit of coding on the PLC side but it's a lot cheaper to use the HMI to simulate IO then to buy a bunch of remote IO.
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
111
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
584
I have a AB SLC503 with a 1747-SN Comm module which I believe is AB Remote IO talking to an old Quick Panel HMI that is now bad. Does anyone know...
1,158
Hi, I have a doubt about the system architecture shows below: could two master devices install in same profibus network?
2,648
Seeking ideas here. This is not really VPN access but just to let someone have view-only access to local HMI screens on their phone from...
3,791
