Remote vpn router setup
adamplc
Dec 2009
usa
92
I am trying to use setup a remote vpn router for external OEM connection.
The thing I cannot wrap my head around is the gateway.
We use the gateway internally to connect to the machine so setting the gateway to the vpn router isn’t an option.
Does anyone in the group know the setup procedure to do this?
I have ****, Siemens and phoenix routers so a broad range to choose from!
Example…
PLC 192.168.1.10 /24
Gateway 192.168.10.1
Router 192.168.1.11 /24
Gateway 192.168.10.1 ??
Then I assume give internet access to the router via port xx plugged into the WAN port.
Then Plug in the lan port into PLC network.
Thanks for any help
192.168.1.10/24 and 192.168.10.1 are in different subnet
The PLC has not access to the gateway
192.168.1.10/24 subnet IPs go from 192.168.1.1 to 192.169.1.254 (.255 can't be used due it's the broadcast address)
The gateway is usually the same router, the same router IP, which is where connections are directed to IPs outside the subnet.
But this is the configuration of the local LAN, nothing to do with the configuration of a VPN.
If that router can act as a VPN server it must have other configurations for it.
Hi guys! My company wants to start offering remote PLC support to our customers. Currently, we use software called LogMeIn, which we can...
18
9,748
We have system platform SCADA GR node and a remote view node via VPN. We have confirmed connectivity between the computers over the VPN pool...
1,184
Could anybody offer any advice on this I have an S7-1500 on a site which I need to connect to remotely with TIA portal. My VPN access is via...
2,618
Hi everyone, Im about to start a project in which I will use AB Compactlogix PLC. It will be a simple installation including -CompactLogix PLC...
2,299
Hi guys, A little off topic, but I just had a thought and wondered if anyone has any information on the following? At a certain site we have the...
2,733
