Big John T
OP
swhite65 said:Then there are many indexing type setups that could use induction motors or servos. The induction motor has the advantage of price. The A-B Ultra drive can be setup for induction motors but I'm not sure how costly that process is. I know that the ABB ACS800 has an offering with a positioning macro. It also would have communication modules to talk with an A-B PLC if necessary to change position presets. Or, this could be done through the keypad on the drive.
Also, don't always take for granted that the application was originally sized correctly. If possible, take some current readings to see what the actual HP and torque requirements are. I have done several retrofits where the original design was extreme overkill which also means very inefficient. Sometimes the production parameters have changed and less power is needed for the current process. I would certainly verify the requirements of the application since you are facing multiple retrofits.
On a servo drive will the amp draw tell me what percentage of power is used like an AC motor? It does look like an overkill but looks can be deceiving...
John
