Good Morning ,
I am replacing a Allen Bradley 1336 Impact drive with a PowerFlex 755. The 1336 had a 1336-L6E /L9E w/ Encoder board in it . The new PowerFlex 755 has a 20-750-ENC-1 ( encoder board ) but the pin outs , Sd, Com, A, B , Z , +24 , and HMC does not correspond with the 1336-L6E /L9E w/ Encoder board that has
B , Not A , Not B , A , +V , 0V . Would any you know if there is a separate manual for the 20-750-ENC-1 ? I have searched and only found an options PDF for the PF 755. I would to find a pin out showing some examples for the 20-750-ENC-1
The encoder that the customer is using is a BEI Technologies .......
HS35F-62-R14-SS-1024-ABZC-4469-SM18-S.
A
B
Z
+V
N.C.
0V
Case
Not A
Not B
Not Z
Shield
1336 -L6E/L9E w/ encoder was using from the encoder..........
Terminal 31 - B
Terminal 32 - Not A
Terminal 33 - Not B
Terminal 34 - A
Terminal 35 - +V
Terminal 36 - 0 V
Thanks so much.
A
B
Z
+V
N.C.
0V
Case
Not A
Not B
Not Z
Shield
Terminal 31 - B
Terminal 32 - Not A
Terminal 33 - Not B
Terminal 34 - A
Terminal 35 - +V
Terminal 36 - 0 V
Thanks so much.
