Replacing ABKF2 Driver
Cabin9663
Jan 2014
Ontario
on a XP PC we were using ABKF2 to talk to a motion controller on a DOS PC emulating PLC5. This driver would not work on Windows7 so we tried the DF1 driver from Kepware and Ingear. In both cases we can access the Boolean tags but none of the Integer or real tags.
Was your Win7 problem that it would not install?
I am pretty sure you can copy the complete installation directory from your XP machine to a Win7 machine & just run the application from there..
Hopefully this works for you.
Welcome to the Forum !
It's likely that the PC-based motion controller implemented only a subset of the PLC-5 command set, and the modern drivers might automatically substitute an SLC command or a different PLC-5 command.
In my opinion, the best way to solve the problem is the capture some of the serial traffic from the existing machine and determine exactly which DF1 function codes are being used, and compare those to the DF1 function codes used by the newer software.
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
110
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
581
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,191
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,469
I have a processer that stopped functioning L32E. The only spare available is an Compact L33ER. Are these processers compatible? The IO is...
2,236
