93lt1
I agree completely!!
saifullah99319's theory of measuring fuse protection in watts goes against everything I have ever learned about fuses.
Tom Jenkins said:There is some dangerous mis-understanding of how fuses work and what the ratings mean going on here. Just because you have a mathematically correct solution, it doesn't mean that the answer correctly represents the physical reality!
I know that a fuse melts because of I-squared-R heating. It is the CURRENT that causes the heating, regardless of the voltage applied. That is why you can use a 120 VAC rated fuse on a 24 VDC circuit.
