Revision # for a Fanuc R30iA controller Main Board?
peelseeds
Mar 2012
Not at your house.
71
I am trying to setup robot DCS, when I configure my safety Enet Module in RSLogix5000 the Revision # is something I'm unsure of. how do I go about finding this information?
update here:
I was able to suck the information from the MODULE INFO tab in RSLogix5000 and I had the revision set correctly but for some reason I still see a yellow "!" beside my module. (safety Ethernet Module in the robot controller, port2)
I had to set my PLC Ethernet submask to 255.255.0.0 in order to see the safety module because the 3 byte in the IP address had to different then the regular Ethernet module in the robot(port 1).
According to my fanuc manual, it tells me I need to "reset ownership" from RSLogix5000 in the module safety tab. when I try to do this I am faced with: " Failed to perform the required operation. Path destination unknown.
if I check my IP settings in the PLC and Robot controller, they are pointing correctly. if I can suck the information from the module, how come RSLogix doesn't see it as configured?
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
161
Hello all, I have been tasked with flashing our processors to the newest version of Studio 5000, and have downloaded the DMK file for the...
260
Hello everyone, My designer software as the 7.200 firmware, but when I go to download to the plc HC900 from honeywell the program I created...
671
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
758
I am working on some documentation in preparation for updating firmware around our plant. On one particular PLC, the point IO has two different...
723
