RFID PcProx to Devicemaster to Controllogix
jeffrey979
Apr 2011
Grand Rapids, MI
I have an application where I am scanning an RFID card on a PcProx (RS232) passing this data to a devicemaster UP 1P 5 and on to the Compactlogix Controller (1768-L43). This a new process for me and I am hoping someone here can give me an idea of what to do to make it work.
I have the devicemaster setup with Ethernet/IP write-to-tag (IP and slot 0), Serial Port with STX/ETX Rx detect (002,003 respectively) with the standard 9600, no parity, 8, 1, no flow.
I'm pretty sure all cabling is accurate and yet I have yet to see the data in the designated controllogix tag. Any help would be appreciated.
Did you program the PcProx? I don't think you need to setup the STX/ETX Rx detect unless you have the PcProx also setup the same way.
What is the tag name in the PLC and what is the data type. I'm just starting to use the devicemaster with a Controllogix and I have an array of SINTS as my tag in the PLC.
Sir,
Thank you for responding, I need all the help I can get.
Another engineer who is unavailable for reference has told me that he didn't need to setup the pcProx at all, however I believe that the setup may be needed.
These are the configurations...
Devicemaster Serial Port Settings:
Mode: RS-232, 9600, none, 8, 1, no flow dtr off, 200ms Timeout is 200ms
Serial Packet ID Settings
STX Rx Detect: one byte, 2
ETX Rx Detect: one byte, 3
Discard Rx Pkts With Errors: yes
PLC Specific Settings
STX Tx Append: one byte, 2
eTX Tx Append: one byte, 3
Strip Rx STX/ETX Chars: no
Ethernet/IP iis 192.168.1.10, slot 0
Tag is DM_Rx_Data which is:
SeqNumber=INT, Decimal
Length=INT, Decimal
Data=SINT[440], ASCII
These are all the settings, all others on the Devicemaster unit are default or not used.
Thanks for any help you can provide.
Jeff Miller
Can you try a tag in the PLC which is just a SINT[440]? I didn't have any luck with the UDT like they show in the manual.
To start I would also recommend installing the PcProx software. You can test and program the badge reader their first.
Hello, I would like to ask you for pcProx Plus rfid reader connection to Pro-Face HMI. RFID Type: RDR-805W1AKU-C72 (RFIDeas) HMI...
1,307
We have a product we are now building and are planning on using RFID tags to ID trays of product as they move through the process (5 individual...
1,446
Hi. I was wondering if any of you guys have a problem with the RFID reader/write BIS M-4A7-082-401-07-S4 from Balluff. The problem we are...
658
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,564
Good Afternoon, I am currently designing an HMI application that needs a screen that shows about 20 of the latest RFID [stored in PLC] and have a...
2,721
