Risks of "Remote Devices Via Linx Gateway"
ckaffer85
Dec 2014
Az
39
Hi All,
I am trying to gather information about the potential risks of using the "Remote Devices Via Linx Gateway" in RSLinx. I will potentially be going from the "cooperate layer" to the "manufacturing layer". The gateway itself does reside in the DMZ. Is there concerns using this type of driver?
Prost!
Chris
What are you calling the DMZ?
we use gateway switches (6) so far to connect DH+ to Ethernet so we can remote into the units or download the program when the plc dumps the program. It's happened several times in the last 5 years.
our plant network is separate from the management network.
if you are calling the corporate layer the DMZ, you need to get away from that quickly and keep the plant network separate.
the IT department will want to force rules on you and require all sorts of things that will make your life awlful.
Firewall rules will prevent your pc from running the software and connecting, your scada system will be slow, need I continue.
regards,
james
Hi all, One of my clients has a Hach sc200 measuring Nitrates (wastewater plant) and the 4-20mA loop works, but the local readout is just...
1,366
I am making some adjustments to a RS View Studio ME application. I am not sure what the passwords are for each level. I am able to get into User...
3,095
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
240
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
286
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
92
