It will be helpful if you state the control platform you are using. I see from previous posts that this might be an AB platform but it is best to restate that in a new thread.
Been messing with it for a bit. Seems like it can do what I need.
A few questions
Not sure what the RMPS does with the PV input. The RMPS calculates the OUT based on time and requested set points...so
right now I dont have PV wired.
Also, at the end of the ramp/soak cycle I have it in HOLD since I dont want cycles repeating right away. Cant seem to figure out the best way to start the same ramp/soak cycle again..basically re running the profile. Right now toggling to MANUAL mode and back to AUTO mode restarts the profile...just wondering if there is a better way.
