RMS Meter on Servo
Brijm
May 2006
St. Marys, PA
645
I have a 3Phase AC Servo Motor on a CNC that is overheating. Unfortunately I don't have an oscilloscope, but I was trying to take some measurements with my True RMS Meters (Fluke 289 DMM 376 Clamp) Both work very well with inverters as advertised. I have never really dug into the operating signals of an AC Servo, but should I doubt my True RMS Meter any more than on inverter.
Thanks,
With inverters I do trust the Fluke... Never varied more than an amp on a new drive. Although with an older drive, I may question the internal meter. The Tech I spoke to however said that it would not work on a 3 Phase AC Servo. Just wondering what the difference.
The drive measures current by looking at the voltage of a low-Ohm resistor in series with the output.
True-RMS digitizes the entire sine wave, then does the math. The RMS function is typically done with a dedicated IC.
The only difference is the coupling method. After that, calculation method should be the same.
I purchased a 4-20ma AC Current Transducer, it can be set to 0-100a, 0-150a, 0-200a. It is not True-RMS. This is connected to a panel meter and I...
1,493
Hi guys, I'm trying to configure a rate of change alarm on a setpoint tag so that when the operator types a number by error (exemple: 30 instead...
175
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
201
Dear Friends, I have few Profinet slaves connected to S7-1200 over Profinet. I wish get alarms and disagnostics from the devices. (IO-Link...
165
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
407
