Robust OPC-HDA client library/component/object?
Pete.S.
Mar 2016
Fl
463
Hi guys!
We need to pull historic data into an application using OPC-HDA.
Searching the net I find plenty of OPC-DA client libraries/components/objects but no OPC-HDA for historic data access. Do you know of any or can recommend anything?
My primary concern is stability - it has to be rock solid.
Thanks,
Pete
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
16
3,998
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,106
Good Afternoon , I have the free version of CCW. Version 11. What is the latest version ? Also , is there a version that is purchased that...
18
6,508
Found an awesome point of sale for $500. It sends an ascii string when a product is sold. Need to convert this into a number between 0 and 255 or...
2,285
I have a client with a problem. He can't find a temperature controller (40mm x 40mm) that panel mounts, and is of sufficient robustness to...
2,148
