Hey there, I see lots of people have had issues over the years with the AENT's. The old series A basically stop doing anything over the network.
I have the series C installed, All seems to work except with RSLogix 5000. RSlinx see's the new unit, I have updated the AOP to work with 5000. I went offline and changed the Series and Revision to what it should be. The AENT operates as it should visibly out on the machine, when you open a door etc the lights all do what they should. Just the RSlogix can't see the new series C
I get the I/O not responding in RSLogix, when I go into properties for the module it says faulted, Code 16#0203 connection timed out. When I go to module info it says no minor or major faults, but internal states says " unconnected" configured says configured owned say "no" identity module says "matched" I have the chassis size set to 4, the module itself plus the 3 DI's.
They only change is that I switch the series A AENT to a Series C. Anything obvious that I am missing?
