Rockwell 1734 and 1718 RIO
Jun 2017
Lisbon
24
HI All,
I would like to know your opinion about the disposition over the 1734 and 1718 rack for the I/O Cards.
- Normally I use for the first positions the AI's, after de DI's, after the AO's and finally the DO's, (I use also this disposition over the PLC Rack/Bus).
- For safety cards (Not used on 1718), I like to use a separated 1734-AENT to can be used there a different RPI, different from the other 1734 island (normally 10ms, I think a never tried less time).
Have you any criterium for that?
Thank you!
3B
Where have you used 1718?
For me it's usually DI, AI, DO and AO. Mostly because AO is not that common.
The 1718, if like 1719, are a bit of a waste of money as you're getting half the product that you should be getting. Nothing new with Rockwell, but still annoying as ****.
Rockwell PLC with 1734-4IOL/A IO-Link Master communicating to 3rd party device. Devices without Premier IODD files normally only have a device...
1,314
Hey there, I see lots of people have had issues over the years with the AENT's. The old series A basically stop doing anything over the network...
2,435
Hi Guys, We Have some problem with 1734-ie2c module with controllogix cpu, sometimes the input value went to 0 without Module alarm. suggestions...
1,522
Hi there, Long time lurker posting for the first time. TLDR: Trying to configure a small Point IO drop into an existing system, the point IO...
23
27,244
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
164
