Rockwell factorytalk view - tag out of service
rtragle
Jul 2015
Bakersfield
19
I'm getting an error when I click a momentary push button
The error that I'm getting is:
Problem writing value 'False' to item (tag)
Write attempt for item (tag) failed (out of service) on route Controllogix in slot 0 of the chassis at (ip)
The tags match in the plc and hmi.
What could be causing this?
Thanks,
Ryan
A couple of things to check:
- Do other tag writes work to the same PLC?
- Is the tag in the controler scope, or a program scope in the PLC? I believe you can write to program-scoped tags, but you have to define the program as well in the tag path
- Is the tag set to allow remote read/write access?
- Have you definitely selected the right PLC shortcut?
- Are you 100% positive your tags match in the PLC and HMI? (the amount of times I've been caught out by switching a full stop and an underscore or something equally as dumb...)
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
551
Is it possible to download and use the Transfer Utility of the Rockwell FactoryTalk View ME ? only the Utility ? without any special requirements...
5,317
Good Morning , I'm getting ready to take the step of retiring our Windows XP laptops. We have a number of older ControlLogix CPU's and...
35
9,523
Is there a way to control 2 tags with the same button in Factorytalk View? Background: I have a motor that has auto enable and manual enable...
9,192
I was debating putting alot of the RA support issues I so far have had with this project, but decided to let is slide and get to the point of the...
5,419
