Rockwell SLC 500 5/05 Ethernet-Ethernet connection
Denker
Feb 2013
Brazil
Hi.
I need to make a Ethernet-Ethernet connection between two Rockwell SLC500 5/05 for data transfer.
Can anyone send me manuals, links and examples of how to do this ?
Best regards.
Hi Mickey.
First thanks for the feedback and the manuals.
I found in Chapter 15 (page 22) an example (Passthru Example: Ethernet to DF1), but it works as a bridge between three SLC5. What I'd like is to make communication between only two SLC5/05 via ethernet. Is there a more specific example for this case (picture attached)?
The manual says to read a step by step example on "Knowledgebase Document Number: G20028 ", but I do not have access there.
Thanks again for the help.
Best regards.
Thank you so much Mickey !
Your welcome, let us know how it works out.
FYI: Your data table addresses , IP addresses and how often you trigger the message instruction will most likely be different.
Read chapter 12 of the instruction set manual.
Mickey,
Please, I've some questions:
1) This programming is done only on one of the SLC 5/05 correct? Or in other PLC (partner) need some extra programming?
2) In your example, only 1 word is being read from N7:0 of 198.168.3.1 controller to N7:0 of Local controller. Am I right ?
3) The element inserted (N7:0) in the "Data Table Address" of "This Controller" and "Target Device" do not need be the same, right? Can I use in "This Controller" N7:0 and in "Target Device" N8:15, for example?
Thanks.
Correct, it can be a read or write.
Yes, but it can be several words. See page 12-13 of the instruction manual.
Correct
Hi, I am trying to integrate my system with a Rockwell SLC-500 PLC. I have the program for the Rockwell PLC with me. I have downloaded the...
3,154
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
697
Machine has existing DN devices that are connected to SLC 5/04. All communication is working fine now. Supplier wants to remove some DN devices...
844
I have a RSlogix 500 I'm trying to convert to Rslogix 5000 and the utility wants a .slc file to work from. when I open the 500 file and try to...
3,251
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
167
