I need to make a Ethernet-Ethernet connection between two Rockwell SLC500 5/05 for data transfer.
Can anyone send me manuals, links and examples of how to do this ?
I found in Chapter 15 (page 22) an example (Passthru Example: Ethernet to DF1), but it works as a bridge between three SLC5. What I'd like is to make communication between only two SLC5/05 via ethernet. Is there a more specific example for this case (picture attached)?
The manual says to read a step by step example on "Knowledgebase Document Number: G20028 ", but I do not have access there.
1) This programming is done only on one of the SLC 5/05 correct? Or in other PLC (partner) need some extra programming?
2) In your example, only 1 word is being read from N7:0 of 198.168.3.1 controller to N7:0 of Local controller. Am I right ?
3) The element inserted (N7:0) in the "Data Table Address" of "This Controller" and "Target Device" do not need be the same, right? Can I use in "This Controller" N7:0 and in "Target Device" N8:15, for example?
Yes, but it can be several words. See page 12-13 of the instruction manual.
