Rockwell Studio 5000 version compatability
jaden
Sep 2009
Pleasant Dale, Nebraska
308
I am trying to connect with a Compact Logix L32E with version 20 firmware.
I have downloaded ver. 20.05 software, it says it is installed successfully, but the L32 processor does not show up as a choice in the Studio 5000. Dealer thinks the older versions don't work with the newer applications? Any ideas?
The 1769-L32E absolutely should be supported by RSLogix 5000 v20.05.
Are any CompactLogix controllers listed in the drop-down menu when you create a new project ?
If you also have v21 or newer software installed, be sure you are opening "RSLogix 5000", not "Studio 5000 Logix Designer".
v20 and prior was "RSLogix 5000", v21 to present is "Studio 5000 Logix Designer".
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
372
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
278
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
306
Hey all, I'm doing a more standardize version of one of my programs and organizing things into UDTs and whatever else I can do to shrink the...
438
Hi All, I have several ACD files & L5X files, I would like to read the contents of these files, however I do not have Rockwell Studio 5000...
2,357
