rotary axis configuration question
mike3475
Feb 2013
brooklyn ,NY
334
Hi, everyone:
I tried to understand the basic knowledge of CIP motion control axis configuration.
we have one rotary axis (kinetix350) in our system, this axis uses MPL-B330P-M motor, i don't understand the system inertia, in our case, the system inertia equals to motor inertia, why the units are different? i don't know where is the system inertia coming from, is there any formula to calculate it or coming from successful autotune?
Thanks in advance!
mike3475;924685i don't understand the system inertia said:
I am confused too.
rev/sec^2 is an angular acceleration.
Inertia have have units of mass so I think the labeling is wrong.
If the software somehow knows about the torque limitations of the motor then is could really be calculating the angular_acceleration limit since torque = rotational_inertia*angular_acceleration.
system inertia = 1/ system acceleration. where is system acceleration coming from? from successful autotune?
thanks!
thanks!
1/ system acceleration is not an inertia. Look up the definition for rotational inertia. System inertia appears to be a "made up" term.
Didn't you see my post above? Torque = rotational_inertia*angular_acceleration. If you rearrange this you get angular_acceleration = Torque / rotational inertia.
You know the rotational inertia and the motor. The motor should have a maximum torque with which the maximum rotational can be calculated. This is basic. Ask Rockwell about their screwed up terms.
An auto tune will provide the open loop frequency and bandwidth or time constant of the motor and load.
I have a very simple application but I'm not very experienced with motion and looking for your advice. I have a rotary axis. Kinetix 5700. I...
3,876
Hi, I have 2 rotary axis on 2 separate belt (servo) that could possibly enter into collision if not properly program and it is giving me some...
2,313
This is not a PLC question, but maybe one of you have seen a product like I am looking for. I have a portable pneumatic misting system that is...
578
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
478
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,473
