Rotating Images FactoryTalk SE
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
Am I crazy, but could you used to be able to rotate objects in FTV by exactly 90 degrees by pressing ctrl while rotating? If not, anybody know how to do this besides "eye-ballin-it"?
I saw there was no reply to this, but if you hold shift while rotating it will snap in the general direction you rotated in if you're close to a 90. Found the thread googling for how to do this and figured it out.
Hello there! I have trying what you suggested but I cannot manage to rotate over its own axis. I want to rotate in place not the whole object. Its weird how this simply option/tool is not available to the naked eye, considering how usual this is.
Any clue ? Thank you in advance for your assistance!
Not sure I understand what you are trying to do. The rotate function isn't a 3D rotate. It is only 2D so you are limited in what you can do.
OG
Thank you for your kind answer. I now understood that Images that have been imported, cannot be rotated to change where they are facing. I had to copy the img that I wanted to rotate to paint, do the rotation there and then import it back without background.
Thank you for your assistance!
It's very embarrassing but when I can't come up with an answer fast, I do need all the help I can get. I have rotating cylinder. One output...
1,600
Hello Gents, I was wondering if anybody on here has used unified faceplates to rotate a shape. I want to be able to rotate a shape 90 degrees...
4,095
Lesson Motor 230VAC-1.2A-1700RPM-62.5PF I am having trouble understanding this. My motor rotates at 0vdc reference with the run forward command...
39
11,763
Looking for a step control program that combines the features of a load sequencing control (3 element heater) with the traditional tasks. . The...
1,825
I just started using AdvanceHMI software. I have two questions. 1. I'd like to make a main menu screen then the operator would select on of 15...
1,636
