rotation of a spray head using analog porportional valve
irondesk40
Jan 2008
nc
630
Have a question that I hope someone may have a answer to.
Have a project where we have a machine that has a spray head that is spraying chemicals on cloth that varies in width.
The spray rotates from 0-45 degrees depending upon the width of the cloth. At the moment we are experimenting with using a stepper motor and appears to work but still still needs some more work.
Our boss has done a lot of autoclave and steam chamber type projects in the past and is wanting us to see if we could this this same type of rotation of a spray head using a pneumatic rotary type 4-20ma porportional valve. I have done a couple of projects in the past using porportional steam valves on autoclave machines to control the temperature in the vessel depending upon the pressure.
I have done some searching on the internet and see where you can get rotary pneumatic proportional valves with positioner units that accept a 4-20 ma signal.
Has anyone on this site ever did a project similar to this, and if so would be willing to share a little information.e
Our boss keeps saying he thinks there is a better way than using a stepper drive, which to him just seems way too complicated, and you know how it is, the boss may not always be right, but he is the boss.
Thanks, hope the question makes sense
How quickly does this thing need to cycle through the rotation? My guess is you may have bandwidth limitations with a pneumatically actuated force balanced system.
Keith
not something that will have to happen very quickly. will be a menu in the operator screen where you select the width and it will rotate to match the width. Have that code working with a stepper motor, but been asked to see if a pnuematic porportional valve could be used and controlled with a 4-20ma signal
Forget pneumatics. Sounds like something can can be easily done with a simple, small, linear positioner (ELECTRICAL), and mounting the head on a pivot.
JMHO. I'm starting to work hard at eliminating as many pneumatic controls as possible. (Okay, so to that extent, I'll be 'Green').
You won't get good position control with a pneumatic system with a PLC Because air has such a low bulk modulus (it compresses easily) it is difficult to accurately control position with it. It can be done, but it will require a good motion controller.
I'll second rdrast's suggestion, use a simple self contained electrical linear actuator.
I think what irondesk40 is looking to do is tear the guts out of a process valve and use that as the head positioner. So it is a pressure controlled force balance system. Quite a bit of care is taken in the construction of those valves to make sure that the command you give them results in a (reasonably) deterministic output. So I would think his positioning accuracy would be OK. I think it will just take him forever to get there. He also may need some damping if he tries to move quickly and the spray head is "heavy".
That being said, I think he should stick with what he has right now unless he has a specific issue he needs to fix.
Keith
Keith -
Not exactly. Every pneumatic control valve we have that is used in an actual positioner application has an attached, pneumatic position controller as well. Just taking the bell and stem won't work, as the bell and the spring are very non-linear devices.
Running a control LOOP using a control valve without positioner is possible, but only because you don't care where the stem is, just that the final (and external) PV is controlled.
Besides that, jeez... even a small control valve, (assuming he just wants to use the bell and stem) is certainly not an inexpensive item. I've got baby, low pressure Research (brand) pneumatic valves here that are over $5000 each.
Hello everyone. I am trying to figure out what the best way to control three pumps would be. I have searched the forums and cannot seem to find...
2,327
Hello all, I am working on a project in FactoryTalk SE. Suddenly while working on a new screen, the global objects I am copying to it are not...
1,275
Good evening once again everyone, I have a Lenze ESV222..... I would like to set it for use with Local keypad and my concern is the rotation...
962
WARNING 🤷 ELECTRICAL NOT PLC I finally got myself a phase rotation meter cause its so hard to tell a well guarded motor's rotation. I also...
29
10,711
Easybuilder Pro. Loving it, but I can't figure out how to simply rotate an object. I don't mean with animation, or based on value. Simply put a...
3,197
