RS-232 Port on SLC 5/03's / 5/04's
Dave McGlynn
May 2003
Auburn Hills, MI
18
Hello,
I have a situation where I'm using an AB SLC 5/03, and I'm using the DH-485 port for a network of panelviews, and I typically use the RS-232 port for a link to an AIC+, and then out to a different DH-485 network, which eventually leads to a data-collection computer.
Well, I also have an engraving machine, that only spits ASCII data out of it's serial port. So, my question to all of you is,
Does AB make a card that will allow me to have another RS-232 port?
Or if I use the original RS-232 port for my engraver, is there a card that will allow me to link the SLC to my other DH-485 network?
I've searched on AB's website all over, but couldn't find anything..
Thanks,
-Dave
Re: Use port multiplexor
Jiri Toman said:
Use MuxiPort to split the RS-232 port on the SLC 5/04. It will give you the ASCII as well as DF1 capability you are looking for.
www.tomantron.com
It looks like this device only lets you use DF1 and ASCII, .. but I need DH-485, right? .. or does the SLC use DF1 between itself and the AIC+ ..?
I think the simplest thing would be to use an A-B 1747-BAS or Prosoft MVI46-GSC module to interface to your ASCII engraver device. That will leave your existing two DH-485 networks in place and put the burden and complexity entirely in ladder logic and a specialty card.
The MuxiPort would be ideal if your second port was strictly DF1, not DH-485. To use it in this application you'd also need a 1747-KE module to convert from DF1 to DH-485, which will increase your cost, size, and complexity.
If you were using DeviceNet, I'd have a handful of suggestions for you, but we'll leave that topic for another day.
The 1747-ke DH485/RS232C interface module has a config, DF1, and a DH485 port on it (2 9pin ports-config & DF1).
1747-KE
Everything I'm finding online talks about using this card with a modem.. Has anyone else out there got any experience with it?
Can this card be plugged into an AIC+ to give me an additional DH-485 communications port?
The 1747-KE converts between DF1 protocol and DH-485 protocol (that's why it has one port for each, plus one for menu-driven configuration).
DH-485 protocol uses some strict timing rules and therefore can't be run over a modem connection. That's why most uses of the 1747-KE are for systems that include modems; the DF1 protocol runs fine over asynchronous media like modem connections.
It was originally used for SLC-5/01 and 5/02 systems that had no DF1 serial port, and retains popularity for SLC-5/03,4,5 systems that are using their Channel 0 serial port for something else.
It's possible for you to hook up a MuxiPort to split your Channel 0 DF1 port into ASCII and DF1 ports, then connect the DF1 side to the 1747-KE, which then connects to your existing DH-485. That's a little more complicated than I like to make things.
Probably the Prosoft MVI46-GSC is the simplest solution to your "I need an ASCII port" problem.
Prosoft also makes an external 3 port expander device that connects to the DF1 RS232 port. The model number is 4102 or something close to that. See this LINK. It's about $500.00 less, however, I had a very hard time working with it. Looking back I know that the lower initial cost was lost in programming time.There are some other advantages to using the MVI46-GSC that Ken could probably point out.
There is also a 1746-BAS Basic module to add a port. I don't know anything about it, I have seen one, that's all.
Sid
Hi, I want to connect a Panel View 300 through Ethernet to an SLC-5/04.But my PLC support RS-232/DH+ and would appreciate some advice on...
4,343
Hello All, Is it possible to send an ASCII string from the RS-232 port of a SLC 5/03 PLC CPU? I'd like to send different strings of data eg...
4,231
I know.....the topic that wouldn't die. lol Has anyone been able to use the "no serial port" laptops with a USB com port to program the Allen...
5,105
Hi all I saw something very weird yesterday and today. Has anyone seen the RS232 port on a slc 5/05 32k revb processor go bad. I am using the...
12,237
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
153
