RS 485 port burn out on CPU
ericsul
Dec 2005
Nethanya
hello,
Anybody knows how to protect port RS 485 on CPU 001 Versamax GEfanuc from electric noise or other RF etc...
The wiring was done as state of the art shielded cable, optical protected converter RS 485-232 from MOXA AS 53 with individual power supply, What do more to prevent this event to happen again?
Thanks for your advices
ERIC
Hello Mats,
Thanks for your reply, what I 'm need to check more than I already did. The power supply is protected and earthed and all the analogue inputs are with cable shielded connected on one side to the ground ???? Which kind of checking you proposed ?
Best regards
ERIC
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
132
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
111
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
748
Hi, I have 1747-L30A Allen Bradley PLC. It has only one DH-485 port. Whenever I have to connect a laptop to the PLC for troubleshooting, I have to...
1,715
