RS 5000 PID and Tasks
MATT116
Dec 2009
Dallas, TX
330
Im using RS5000 V19 with a compactlogix 1769-L32E.
I have 4 PID loops each one controls a valve which in turn controls water flow through a R.O. unit. My question is should I put each PID in its own periodic task or put all 4 in 1 task? Should I only put the PID block in the task or include the associated logic? The associated logic for each PID is only 5 rungs with just simple XIO,XIC and OTE instructions.
Matt
Put all four into the same task, the only reason to put them into separate tasks is if you want to trigger them at a different time interval.
I typically will only put the PID instruction in the periodic task logic, any supporting logic is placed elsewhere. In your case if you just have a few rungs of supporting logic, you can include it in this task too, really depends on how your "process" logic is structured.
Hi ! Here is my first post :) I want to implement three (3) independent PID controlers (block) in a Controllogix controller. They will be used...
2,049
I'm setting up a PID for a 50hp RO pump in a water treatment plant. When I go to manual mode on hmi I set the swm bit, I also ons the pid output%...
591
Hello all, I'm having issues with a PID and trying to tune it. I just do not understand why my CV goes to 105 with the settings I have. Config...
1,583
Hi All, I'm using Studio 5000 ver 30 to modify existing logic that has PID, and I want to be able to use an external/remote source as a setpoint...
640
Hi, Long time not in the forum, and not in the programming. I´m getting back. I was issued a conversion from RSLogix 500 to RSLogix 5000 (studio...
1,298
