RS Linx and PIC driver
HJTRBO
Jul 2008
Melbourne
618
Hi I couldn't get the PIC driver started today. I have never used it on this laptop and had to borrow a workmates laptop instead. I was making a change to a panelview 550. I have attached a photo of my error. I don't know much about AB so maybe I missed something easy? What I can say is that I have used the RS232 DF1 serial driver and ethernet drivers with my laptop and never had any problems. I am running XP Pro SP3 and RS Linx version 2.57 through VMPlayer and I have a real serial port on the host.
I would be grateful for some help please. I didn't have much luck searching.
I believe it is a SP3 problem, if you do a search in the last few days of posted I am sure there was a post about it, one of the forum members has a procedure to fix the problem, something to do with SER_NUM.
Alan
Alan
Thank you Alan, I found the thread here http://www.plctalk.net/qanda/showthread.php?t=63919&highlight=sp3
I usually skip over the AB threads šŸ™ƒ
This has got the driver started which sounds like the hard part according to my research. I wont get a chance to test it again till next week but I think i'll be sweet now mate. Cheers, Nathan
I installed RSlinx Lite to a new laptop running on Win 7 and when i tried setting up the drivers, i noticed that there was no driver for...
19,811
Hello All, This is in continuation with the Fatal Error for AIC/PIC Driver on RSLinx while trying to download Application file to Panelview300...
7,085
The tittle mainly says it all. I tried to add a new driver (1747-PIC) to RSLinx Classic 2.50 and when I click on ADD NEW it does nothing at all...
4,657
"Can not create new PIC device when RS Linx is running as a service, to create a new PIC device, run RSLinx as a normal application" That is the...
6,123
I am having windows XP on laptop. it has a serial port. I am using RSLinx 2.30. I am not able to see the PIC driver in driver list during...
8,016
