**RS Linx** Ethernet IP driver doesn't see controller over wireless.
snakes79
Nov 2015
Illinois
17
Hello all.
I am running RSLinx 3.81.00 CPR 9 SR8.1 and my EthernetIP driver doesn't work with my wireless card. I can still ping the addresses , and the ethernet driver works just fine. Got any ideas?
Thanks!
Try this. Right click on the driver in RSLinx and select Configure Driver. You will most likely see 3 selections in the list, Windows Default, your wired and your wireless adapter. Select your wireless adapter and click Ok.
I ususally then right click on the driver again and select Remove. Then click up on the top level item (Workstation) and it will put the driver back in again and rescan. This isn't exactly required but I find it refreshes faster doing this.
What Windows are you running? Is there a VM involved?
I primarily use wireless to talk to PLC's so that certainly isn't an issue. My Rockwell software is in a VM so that can take a little extra configuration.
How does RSLinx Classic EtherNet/IP Driver "Windows Default" adapter relate to the all of the available Windows adapters? Is there a way to...
2,501
Hello Friends, 1. How can I connect to PLC5/30 via Ethernet (Rslinx)?. I have not worked on PLC5 before. is it same procedure as MicroLogix...
2,193
Under the "Ethernet devices" driver from RSLinx, I see all my remote devices when my laptop's wifi is enabled. Under the Ethernet/IP driver, I...
4,885
Hello, Any help! My Rslinx classic with version 3.8, Ethernet /IP Driver cannot detect anything within the network, but using the ethernet...
6,767
I am having an issue where we just implemented a VLAN switch (NTRON brand). The switch seems to be working fine. I can ping the devices and also...
4,487
